1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: "assert (this->exitWait ( DBL_MAX ))" failed
To: [email protected]
Date: Mon, 08 Dec 2003 18:12:34 -0500
I noticed the following message on the "medm screen"
because today users complained that they could not pop up
the xyz.adl file from the "related display" :
A call to "assert (this->exitWait ( DBL_MAX ))" failed in
.../../../src/libCom/osi/epicsThread.cpp line 60.
EPICS Release EPICS R3.14.0.beta.2 $R3-14-0-beta-2$ $2002/07/30
21:40:55$.
Current time Tue Dec 02 2003 22:16:11.849753000.
Please E-mail this message to the author or to [email protected]
Calling epicsThreadSuspendSelf()
It seems to be an intermittent problem because it is the first
time that it occurs.  Meanwhile, I could not load any new file
via "File" from the original medm session.  Without killing the
original one,  I opened another medm session and I was able
to pop up the xyz.adl via "File" or the "related display".
Something we can get around.  It seems the IOC works fine.
The platform :
Medm version 3.03.
The IOC is running R3.14.0.beta.2 VxWorks thread.
One thing to mention is that :
Whenever the IOC was first rebooted, I always got the following
error message in the VxWorks thread (but never in the RTEMS
thread. Unfortunately I did not run RTEMS on that IOC because
I would have to borrow a mvme2306 from other projects to run) :
0xa36af0 (dnsQuery): Unhandled C++ exception resulted in call to
terminate
Something that was referenced in tech-talk  "dnsQuery task suspended"
by Geoff Savage on Sep. 5, 2003.
However, it seems that the VxWorks IOC has been running fine for six
months.  The error message I  mentioned on the top is
found in the medm screen.
kate
RE: "assert (this->exitWait ( DBL_MAX ))" failed Jeff Hill
Prev: Re: Novice EPICS questions re yet another port Eric Norum
Next: RE: "assert (this->exitWait ( DBL_MAX ))" failed Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: scanRecord for 3.14 Marty Kraimer
