1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Linking Unix Matlab-Compiled Programs against MCA
To: [email protected]
Cc: Stephanie Allison <[email protected]>, Tech-talk <[email protected]>
Date: Tue, 16 Dec 2003 10:09:15 -0500
I'm not sure which version of MCA you are using, but suggest trying one
of our SNS versions, available at http://ics-web1.sns.ornl.gov/mca.html
There are versions for EPICS R3.13 and R3.14.
If you have stability problems with these, please inform me.
Carl
On Tue, 2003-12-16 at 01:14, [email protected] wrote:
> Hi Stephanie,
> I noticed your question regrading linking of MCA on linux which you posted
> to tech-talk in October 2002.  Did you have any success with that?
> We're currently looking a Matlab with the idea of using it as part of our
> control system for the Australian Synchrotron, and I'm evaluating it on a
> Red Hat linux box at the moment.  I've successfully compiled MCA (in
> particular mcamain.cpp) and have a little example application up and going
> which monitors one process variable. I've found it to be very unstable... I
> very frequently get segmentation faults when I run the application and,
> after some debugging, the problem appears to be within MCA itself.
> I don't suppose you've run into anything like this in your investigations?
> My next step is to try it out on Windows and see if I get the same
> instability.
> Steve Banks
> Australian Synchrotron Project
> Department of Infrastructure
> Level 18, 80 Collins Street
> Melbourne   VIC   3000
> tel:  +613 9655 6303
> fax:  +613 9655 8666
> web: www.synchrotron.vic.gov.au
Carl Lionberger
SNS Control Systems Group, ORNL
Phone: 865-574-7636
Fax:   865-241-6739
Re: Linking Unix Matlab-Compiled Programs against MCA Steven . Banks
Prev: Re: mosub record and R3.14 Andy Foster
Next: Re: Spurious link alarms generated? Marty Kraimer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Linking Unix Matlab-Compiled Programs against MCA Steven . Banks
Next: RE: Linking Unix Matlab-Compiled Programs against MCA Allison, Stephanie
