1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: mosub record and R3.14
To: "'Andy Foster'" <[email protected]>
Cc: Epics Questions <[email protected]>
Date: Tue, 16 Dec 2003 07:40:01 -1000
Thanks Andy.
John has sent me a copy of his genSub record.
I hadn't realized that mosubs were replaced by genSubs.
We're using both record types here so it's no problem
converting mosubs to genSubs.
Mahalo!
Kevin
-----Original Message-----
Sent: Monday, December 15, 2003 11:57 PM
To: Kevin Tsubota
Cc: Epics Questions
Subject: Re: mosub record and R3.14
Aloha Kevin,
John's message sums it up nicely.
The "mosub" was an early attempt at creating a record
which had multiple outputs. I replaced this with
the "genSub" which has all the functionality of the
"mosub" plus more.
I would suggest you replace your "mosub's" with "genSub's".
Let me know if you would like a copy of the 3.14 "genSub"
record.
Cheers,
Andy
On Mon, 15 Dec 2003, John Maclean wrote:
> Kevin,
> Andy Foster wrote the mosub record and he fairly quickly replaced it
> with the genSub record IIRC.
> I don't know if Andy is still supporting the mosub, but I have converted
> the genSub to 3.14.4, I can send you this if you wish. Andy also has my
> changes and may well have added to them by now.
> I'd suggest you go to 3.14.4 and don't bother with 3.14.1. There have
> been quite a few changes since 3.14.1. See the release notes for the
> gory details.
> HTH,
> John.
> Kevin Tsubota wrote:
> > I have an existing database that doesn't talk to any hardware and  I
would
> > like to convert
> > it over to R3.14.1 as a test, but it uses mosub records which isn't part
of
> > base.
> > Has anyone converted the mosub record to R3.14 yet and can I get a copy?
> > Thank you very much.
> > Kevin Tsubota
> > W.M. Keck Observatory
Observatory Sciences Limited    Email: [email protected]
William James House             Tel: 44 - (0)1223 - 508259
Cowley Road                     Fax: 44 - (0)1223 - 508258
Cambridge, CB4 0WX, UK          http://www.observatorysciences.co.uk
Prev: RE: Linking Unix Matlab-Compiled Programs against MCA Allison, Stephanie
Next: RE: Linking Unix Matlab-Compiled Programs against MCA Steven Hartman
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: mosub record and R3.14 Andy Foster
Next: CA_UDP error message 하기만
