1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Linking Unix Matlab-Compiled Programs against MCA
To: "'Steven Hartman'" <[email protected]>, "'[email protected]'" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Tue, 16 Dec 2003 14:04:08 -0800
We at SLAC have not been using Linux, but only Solaris, just as Steve Hartman describes below. We have been successful in compiling Matlab with mca. As I remember, it was fairly straight-forward.
See http://www.slac.stanford.edu/grp/cd/soft/share/slaconly/matlab/index.html
/Ron Chestnut
-----Original Message-----
Sent: Tuesday, December 16, 2003 11:15 AM
To: '[email protected]'
Cc: EPICS tech-talk
We've been using a slightly modified version of SNS's mca under Solaris (Solaris 7 and 8, EPICS R3.13.7, matlab 6.1). We use it primarily for diagnostics and machine studies. Stability has been reasonably good. The failures we do see are mostly related to timeouts. These can typically be coded around in the matlab script on a case-by-case basis (using mcamon, or try/catch). We did have more problems with mca connecting to PVs from a labview program (interfacing gpib instruments) using the activeX ca server. These PVs have since been moved to a 3.14.4 linux ioc using a linux-gpib library, which eliminated nearly all the problems we had been having with mca connecting to these PVs.
We are not yet using compiled matlab programs using mca, but do have plans to do this. I believe one of my colleages here has done this as a test case, but not yet for normal usage.
Steve Hartman
[email protected] | 919-660-2650
Duke Free Electron Laser Laboratory
Prev: RE: Linking Unix Matlab-Compiled Programs against MCA Steven Hartman
Next: SBS IP module support? Laznovsky, Michael
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: about edm1-10-0s-beta zhaozhuo
