1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EPICS time
To: <[email protected]>
Date: Mon, 22 Dec 2003 13:25:38 -0600
Folks,
I have a problem and a question about EPICS time under vxWorks in 3.14.4.
Problem: The environment variable EPICS_TS_NTP_INET is supposed to allow me to specify the IP address of an NTP server.  My boot host (Windows) is not an NTP server, so I have used this environment variable to specify a valid NTP time server.  This works fine under 3.13.7.  However, when I boot the same system from 3.14.4 it does not work, I get an "iocClockSyncWithNTPServer: sntpcTimeGet S_sntpcLib_TIMEOUT error", and the "date" command says it's 1989.
Question: The environment variable EPICS_TS_MIN_WEST was used under 3.13 to set the timezone.  This is no longer documented in 3.14.4, and indeed does not work.  However, I could find no replacement variable documented either.  Typing "envShow" in 3.14.4 shows that there is now an environment variable TIMEZONE which seems to set the timezone.  Is this the correct way to do it, and if so what is the correct syntax.  The value on my system is set to:
TIMEZONE CUS::360:040602:102602
Does this mean Central US, minutes west of Greenwhich and the start and end date of daylight time in 2002?  If I want US eastern time this year what do I set this to?
Mark Rivers
Prev: swRecord.dbd for TDS Kiman Ha
Next: RE:swRecord.dbd for TDS Kiman Ha
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE:swRecord.dbd for TDS Kiman Ha
Next: EPICS R.314.4 for solaris-sparc-gnu build problem Kevin Tsubota
