1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: buying tornado seats for EPICS application developers
To: EPICS tech-talk <[email protected]>
Date: Fri, 30 Jan 2004 09:38:03 +0100
Jeff Hill wrote:
I am in the process of renewing our vxWorks maintenance. Unfortunately, WRS
still does not have a two tier licensing scheme for users of Tornado GUI
tool verses folks that are just building and installing executables with
scripts (i.e. typical EPICS application developers).
Does this not really come back to the question which license is necessary just to be allowed to use the Tornado header files? - And why?
In any case isn't it enough to have one license in house to compile anything?
As far as I can see our developers here we just use the GUI tools to generate new Tornado images. Debugging on the target is not used. Therefore we've already reduced the number of developer seats.
It occurs to me that
there is a potential to significantly reduce the cost of Tornado ownership
at EPICS installations. It seems that if someone were to modify the SNL
compiler so that it produced byte code which is interpreted at run time
(similar to JAVA) and there was an option to create an alternative IOC
configuration where dependence on the target symbol table by vxWorks
compiled iocCore was removed (we already have this working on other OS with
R3.14), then the application developer wouldn't need to use a Tornado seat.
Again - why would an application developer need a seat? Isn't one license enough? The number of seats limits the number of concurrent developer/ online debugging sessions. Is the number of developers using the header files limited?
On the other hand I like the idea to look into the byte code option:
Why similar to Java? Why not running a Java VM on the IOC?
What are the chances and the risks doing that - and which other licenses might be necessary? Applications with high demand in functionality and low performance might benefit from the Java approach.
And - there's only one byte code running anywhere.
Comments?
Sites might need to buy Tornado seats for building EPICS base and for
developing drivers, but not for developing EPICS function block databases or
to develop SNL based logic.
I was just curious if there was any general level of interest in that
approach?
P.S.
I just heard that there is a new 8k US $ per year per seat licensing model
from WRS which allows unlimited use of any hostArch / targetArch / project
permutation by one user.
We are working on the same problem and heard a similar rumor in Germany.
We hope that the service contract for this year might already be based on such an approach.
-Matthias
buying tornado seats for EPICS application developers Jeff Hill
Prev: Re: buying tornado seats for EPICS application developers Till Straumann
Next: Re: buying tornado seats for EPICS application developers D. Peter Siddons
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: buying tornado seats for EPICS application developers D. Peter Siddons
Next: RE: buying tornado seats for EPICS application developers Hunt Steven
