1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ChannelArchiver and gcc 3.2.2 on linux
To: Peter Groszkowski <[email protected]>
Cc: Tech-Talk <[email protected]>
Date: Wed, 04 Feb 2004 17:19:25 -0800
Peter,
I have compiled and am running the ChannelArchiver on the same
version of Linux that you are running.  However, it is a later
version of ChannelArchiver (the final for EPICS 3.13.x) which
was rewritten to eliminate the code that is causing your problem.
I downloaded channelarchiver-1.10.2.src.zip from 		http://ics-web1.sns.ornl.gov/~kasemir/archiver/index.html
	<http://ics-web1.sns.ornl.gov/%7Ekasemir/archiver/index.html>
Hoping this helps,
Susanna
Peter Groszkowski wrote:
>   Hello:
> Let me quickly outline my system configuration:
> Epics version: 3.13.9
> ChannelArchiver version: 1.9.1
> OS: RedHat9 ( kernel 2.4.20)
> gcc version from running 'gcc -v':
> Reading specs from /usr/lib/gcc-lib/i386-redhat-linux/3.2.2/specs
> Configured with: ../configure --prefix=/usr --mandir=/usr/share/man
> --infodir=/usr/share/info --enable-shared --enable-threads=posix
> --disable-checking --with-system-zlib --enable-__cxa_atexit
> --host=i386-redhat-linux
> Thread model: posix
> gcc version 3.2.2 20030222 (Red Hat Linux 3.2.2-5)
> I was wondering whether anyone has been using the ChannelArchiver under
> RedHat9. I am having a few minor compilation issues which I believe may
> be related to my version of gcc.
> Essentially the problem is due to a line (in two different files):
> _file.unsetf (std::ios::binary);
> where _file is an object of type std::ifstream. The error I get is:
> In file included from ../ASCIIParser.cc:6:
> ..../ASCIIParser.cpp: In member function `bool ASCIIParser::open(const
> stdString&)':
> ..../ASCIIParser.cpp:25: no matching function for call to `
> std::basic_ifstream<char, std::char_traits<char> >::unsetf(const
> std::_Ios_Openmode&)'
> /usr/include/c++/3.2.2/bits/ios_base.h:361: candidates are: void
> std::ios_base::unsetf(std::_Ios_Fmtflags)
> gmake[1]: *** [ASCIIParser.o] Error 1
> gmake[1]: Leaving directory
> `/usr/local/epics_versions/epics3.13.9GEM8.5/extensions/src/Tools/O.Linux'
> gmake: *** [install.Linux] Error 2
Susanna Jacobson                MS 10-110
[email protected]              Lawrence Berkeley National Laboratory
VOICE:  (510) 486-7801          1 Cyclotron Road
FAX:    (510) 486-7374          Berkeley, CA 94720
ChannelArchiver and gcc 3.2.2 on linux Peter Groszkowski
Prev: Unix Pretty-print for .st (SNL, or Sequencer programs) Chestnut, Ronald P.
Next: seq 2.0.7 now available Laznovsky, Michael
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: ChannelArchiver and gcc 3.2.2 on linux Kay Kasemir
Next: edd/dm and Red Hat Linux Nick Rees
