1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: How is it that IOC process only 11000 records per second at AMD Duron 850MHz?
To: [email protected]
Date: Sun, 15 Feb 2004 22:00:26 +0600
Hello,
850MHz?
R3.14.5 works at RedHat 8. Database consist of 40000 ai records,
synchronous devAiSoft servers all records, routine increments value
pai->val. if records is scanned with o.1sec interval, then some PVs does
not changes
"if a device causes delays of greater than 100usec
then asyn device support is appropriate." from IOC guide ch.12
Is restriction determinate RTC effect? x86 has worked with 100Hz, 68K has
60Hz?
"68040 IOC can process more then 6000 records per sec" IOC guid 3.2 basic
attributes.
RTC_x86/RTC_68K=1.7  mavPV_x86/maxPV_6=11000/6000=1.8
thank you
Best Regards,
Tatiana
Budker Institute of Nuclear Physics
prospekt Lavrentev  11
630090, Novosibirsk, RUSSIA
fax     +7 3832 342163
phone   +7 3832 394977
e-mail: [email protected]
Prev: Re: CA question Till Straumann
Next: RE: How is it that IOC process only 11000 records per second at A MD Duron 850MHz? Hunt Steven
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: RE: CA question Jeff Hill
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
