1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Lx ioc-shell chrashes
To: [email protected]
Date: Fri, 27 Feb 2004 13:15:46 +0100
I have tried to load an ao-record with a PV-Link. If this PV unknown, the
ioc-shell crashes at init-time.
The first time I used Base3.14.2, now I'm using Base-3.14.5.
Both have produced the same errors.
I have excluded all unimportant files.
(Linux Kernel 2.4.18)
Thanks Frank.
An example that works:
record(ao,"hi:de_pid") {
	field(DESC,"analog output")
	field(DTYP,"Soft Channel")
	field(DOL,"1")
        field(PREC,"3")
	field(OMSL,"closed_loop")
record(ao,"ho:e") {
	field(DOL,"hi:de_pid.VAL")
        field(PREC,"3")
Example does'nt work:
record(ao,"ho:e") {
            field(PREC,"3")
The shell window shows below:
hoeft@captain:/home/epics_usr/tstdb/iocBoot/ioctpsd$ ../../bin/linux-x86/tpsd
st.cmd
< envPaths
epicsEnvSet(ARCH,"linux-x86")
epicsEnvSet(IOC,"ioctpsd")
epicsEnvSet(TOP,"/home/epics_usr/tstdb")
epicsEnvSet(EPICS_BASE,"/opt/base-3.14.5")
cd /home/epics_usr/tstdb
dbLoadDatabase("dbd/tpsd.dbd")
tpsd_registerRecordDeviceDriver(pdbbase)
dbLoadRecords("db/dbExample1.db","user=epics_usrHost")
dbLoadRecords("db/dbExample2.db","user=epics_usrHost,no=1,scan=1 second")
dbLoadRecords("db/dbExample2.db","user=epics_usrHost,no=2,scan=2 second")
dbLoadRecords("db/dbExample2.db","user=epics_usrHost,no=3,scan=5 second")
dbLoadRecords("db/dbSubExample.db","user=epics_usrHost")
dbLoadRecords("db/pid_sub.db")
cd /home/epics_usr/tstdb/iocBoot/ioctpsd
iocInit()
Starting iocInit
###  EPICS IOC CORE built on Feb 24 2004
###  EPICS R3.14.5 $R3-14-5$ $2004/02/04 20:45:33$
Frank Hoeft                                        Tel. : ++49-30-6392-4679
BESSY                                              FAX  : ++49-30-6392-4980
Albert Einstein Straße 15                     email:  [email protected]
12489 Berlin
Germany
Prev: Re: Problem of NORD field in waveform (R3.14.4) Marty Kraimer
Next: print from interrupt D. Peter Siddons
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
