1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: print from interrupt
To: "D. Peter Siddons" <[email protected]>
Cc: Mark Rivers <[email protected]>, [email protected]
Date: Fri, 27 Feb 2004 16:22:53 -0600
D. Peter Siddons wrote:
Thanks to all who responded. I should have made it clear that I was talking about an RTEMS app., which only has epicsInterruptContextMessage(), which can only print a string, no formatting. Eric Norum suggested using snprintf() to fill a buffer and pass that to epicsInterruptContextMessage(). That seems to work fine. I had the impression before that calling any of the xprintf() commands from within interrupt context wasn't allowed, but apparently the string variants are OK.
Pete.
The string variants can't ever block so they're safe to call from an interrupt handler -- with one small caveat. Interrupt handlers typically do not have their own floating point context so you've got to ensure that snprintf does not execute any floating-point instructions.
Eric Norum                                 [email protected]
Advanced Photon Source                     Phone: (630) 252-4793
Argonne National Laboratory
Re: print from interrupt D. Peter Siddons
Prev: Re: gtr1-2 for SIS3301. Andrew Johnson
Next: OMS VX2-006 motor controller problem Ronald L. Sluiter
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: print from interrupt D. Peter Siddons
Next: Re: print from interrupt Allan Honey
