1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: gtr1-2 for SIS3301.
To: [email protected]
Cc: [email protected]
Date: Mon, 01 Mar 2004 10:22:27 -0600
[email protected] wrote:
I have BSP compile errors, when the added univDma.c.
c:\Tornado2.2\target\proj\Prj_sis3301\default\C:\Tornado2.2\target\config\mv5100\univDma.c :240: undefined reference to `sysLocalToPciAdrs'
Oops, I didn't realize I was using that routine here - add this function somewhere, I have it in sysLib.c:
/****************************************************************************** * * sysLocalToPciAdrs - convert a local address to a pci address * * This routine returns a PCIbus address as it would be seen on the bus. * The local address that is passed into this routine is the address of * the local resource as seen by the CPU. * * RETURNS: OK, or ERROR if the mapping is not possible. * * SEE ALSO: sysPciToLocalAdrs() */
STATUS sysLocalToPciAdrs
    int adrsSpace,	/* whether I/O or Memory address */
    void *adrs, 	/* local address to convert */
    UINT32 *pPciAdrs	/* where to return pci address */
    if (adrsSpace & PCI_BAR_SPACE_IO)
	if ((adrs >= (void *) PCI_MSTR_IO_LOCAL) &&
	    (adrs < (void *) (PCI_MSTR_IO_LOCAL + PCI_MSTR_IO_SIZE)))
	    adrs += PCI_MSTR_IO_BUS - PCI_MSTR_IO_LOCAL;
	else
	    return ERROR;
    else /* PCI Memory space */
	if ((adrs >= (void *) LOCAL_MEM_LOCAL_ADRS) &&
	    (adrs < (void *) sysPhysMemTop()))
	    adrs += PCI_SLV_MEM_LOCAL - LOCAL_MEM_LOCAL_ADRS;
	else if ((adrs >= (void *) PCI_MSTR_MEM_LOCAL) &&
		 (adrs < (void *) (PCI_MSTR_MEM_LOCAL + PCI_MSTR_MEM_SIZE)))
	    adrs += PCI_MSTR_MEM_BUS - PCI_MSTR_MEM_LOCAL;
	else
	    return ERROR;
    *pPciAdrs = (UINT32) adrs;
    return OK;
For completeness (although it's not needed by univDma.c) there is a companion function to the above which I also provide in my BSPs:
/****************************************************************************** * * sysPciToLocalAdrs - convert a pci address to a local address * * This routine returns a local address that is used to access the PCIbus. * The bus address that is passed into this routine is the PCIbus address * as it would be seen on the bus. * * RETURNS: OK, or ERROR if the mapping is not possible. * * SEE ALSO: sysLocalToPciAdrs() */
STATUS sysPciToLocalAdrs
    UINT32 adrs, 	/* pci address to convert */
    void **pLocalAdrs	/* where to return local address */
	if ((adrs >= PCI_MSTR_IO_BUS) &&
	    (adrs < (PCI_MSTR_IO_BUS + PCI_MSTR_IO_SIZE)))
	    adrs += PCI_MSTR_IO_LOCAL - PCI_MSTR_IO_BUS;
	else
	    return ERROR;
	if ((adrs >= PCI2DRAM_BASE_ADRS) &&
	    (adrs < (PCI2DRAM_BASE_ADRS + DRAM_SIZE)))
	    adrs += LOCAL_MEM_LOCAL_ADRS - PCI2DRAM_BASE_ADRS;
	else if ((adrs >= PCI_MSTR_MEM_BUS) &&
	    (adrs < (PCI_MSTR_MEM_BUS + PCI_MSTR_MEM_SIZE)))
	    adrs += PCI_MSTR_MEM_LOCAL - PCI_MSTR_MEM_BUS;
	else
	    return ERROR;
    *pLocalAdrs = (void *) adrs;
    return OK;
- Andrew -- Dear God, I didn't think orange went with purple until I saw the sunset you made last night. That was really cool. - Caro
Prev: Re: print from interrupt Allan Honey
Next: Problem running edm (EPICS extension) Gaudenz Jud
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: gtr1-2 for SIS3301. Andrew Johnson
Next: OMS VX2-006 motor controller problem Ronald L. Sluiter
