For some reason the top makefile does not build the imagelib code. If
you cd into edm/imagelib and run make it should build and install
lib605432d2-f29d-11d2-973b-00104b8742df.so. To make sure edm recognises
the library you must delete edm/setup/edmObjects and source the setup
script edm/setup/setup.sh. This should fix the help the problem with
help not displaying pngs and gifs, and also add png and gif options to
the graphics menu.
Hope this helps,
Mike
Dr Mike Leech
Computer Systems Manager
Diamond Light Source Ltd.
RE: EtherNet/IP for AB SLC5/05 PLC (and FlexLogix) Rarback, Harvey
rapid scans D. Peter Siddons
<2004>
<2004>
ANJ, 10 Aug 2010 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
