1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Buffer problems
To: "Andrew Johnson" <[email protected]>
Cc: <[email protected]>, <[email protected]>, <[email protected]>, "smtp lanzirotti" <[email protected]>
Date: Fri, 26 Mar 2004 14:22:28 -0600
Dear Andrew,
This problem is becoming critical.  Every vxWorks/PowerPC IOC at the
NSLS at Brookhaven is crashing within minutes if it is connected to the
NSLS network.  The only way the beamlines can run is to disconnect their
switches from the NSLS network.  Tim Mooney told me yesterday that
several CATs are now seeing this problem here as well.  It is not known
if the network activity that is crashing the IOCs is a malicious or not.
Finding the source of the packets at the NSLS is being worked on, but
the real solution is to see if there is a fix for the network software
on vxWorks to make it immune to this problem.  Can you see if Wind River
has a patch that fixes this?
Re: Buffer problems Graham Waters
RE: Buffer problems Ernest L. Williams Jr.
Prev: Re: mvme5500 (was National Instruments VME-MXI-1 modules vs. modernVMECPUmodules) Eric Bjorklund
Next: Re: mvme5500 (was National Instruments VME-MXI-1 modules vs. modernVMECPUmodules) Eric Norum
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Buffer problems Jeff Hill
Next: Re: Buffer problems Graham Waters
