1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ezcaIDL ELF class error
To: [email protected]
Cc: [email protected]
Date: Tue, 30 Mar 2004 11:46:05 -0600 (CST)
>I am having a problem using ezcaIDL with idl 5.5,  things
>work fine on the same computer using idl 5.3. The error is
>shown below.  The OS is Solaris 5.8 (on sparc).
Currently ezcaIDL is built as 32 bit sharable library.
Starting from IDL 5.5 for solaris it assumed that 64 bit code is used.
But it  provides an option '-32' on the command line, it allows the user
to run IDL with 32 bit sharable library.
In order to access the ezcaIDL CA command, you have to start the IDL
with '-32' option:
		idl -32
>Also, is anyone using ezcaIDL with idl 6.0, on Solaris or
>Linux?
At APS we are running both IDL 6.0 and IDL 5.5 on Solaris.
Ben-chin
Prev: RE: CA client: Where should ca_current_context() be used? Jeff Hill
Next: Re: Query on more EDM widgets steiner
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: ezcaIDL ELF class error Mark Rivers
Next: CA client: Where should ca_current_context() be used? Liyu, Andrei
