1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: writing to record
To: "Liyu, Andrei" <[email protected]>
Cc: [email protected]
Date: Thu, 08 Apr 2004 09:06:02 -0500
Liyu, Andrei wrote:
I would like to write to waveform record (long or float type) directly.
At first, I can use dbPutField( ...) but it would take much time because
I need to change 30% of record's array.
At second,
dbScanLock( ...)
write to record array
if I need to give sign CA monitors
	precord->putf = TRUE and dbProcess( ...)
dbScanUnlock( ...)
Am I right?
Thanks, Andrei.
I assume you are concerned about performance and thus want to directly access the array.
I will also assume that your code is not run under a scan task, i.e. it is not part of record or device support or a subroutine connected to a record.
Do the following:
At initialization:
struct dbAddr addr;
dbCommon *pdbCommon;
rset               *prset;
status = dbNameToAddr("<name>",&addr); if(status) /*error handle it!!! */ pdbCommon = (dbCommon *)addr.precord; prset = pdbCommon->rset;
Now get ready to access the array
   long no_elements,offset,nNew;
    double *pdata;
   dbScanLock(pdbCommon);
   status = prset->get_array_info(&addr,&no_elements,&offset)
   /* check the following things to see if your code can handle the array
     Is offset 0?
     The current number of elements is no_elements.
     The maximum number of elements is addr.no_elements.
      Are these OK with you?
     Is addr.field_type OK with you?
     You probable want DBF_DOUBLE.
      This example assumes double
     if(addr.field_type!=DBF_DOUBLE) /*ERROR handle it*/
     pdata = (double *)addr.pfield;
     /* You can now write the data. also set nNew */
     status = put_array_info(&addr,nNew);
     status = dbProcess(pdbCommon);
    dbScanUnlock(pdbCommon);
writing to record Liyu, Andrei
Prev: writing to record Liyu, Andrei
Next: Record processing knowledge of dbAccess context Peregrine M. McGehee
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
