1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Record processing knowledge of dbAccess context
To: "Peregrine M. McGehee" <[email protected]>
Cc: [email protected], [email protected]
Date: Thu, 08 Apr 2004 14:35:53 -0500
Peregrine M. McGehee wrote:
In which case a possible solution for a bidirectional record
(without custom record types but with custom device support) is:
record A : input record with custom dev sup, scan PASSIVE
record B : periodically scanned record, with FLNK to A
within A's read_xxx device support function:
     if PUTF true then
    grab VAL and write to hardware
     else
    read from hardware and write to VAL
This writes on demand from the CA client and reads periodically.
This should work but if anyone ever uses A in a different way, e.g. an output link is directed to it then it will fail.
Marty
Re: Record processing knowledge of dbAccess context Peregrine M. McGehee
RE: Record processing knowledge of dbAccess context J. Frederick Bartlett
Prev: Re: Record processing knowledge of dbAccess context Marty Kraimer
Next: Re: Record processing knowledge of dbAccess context Peregrine M. McGehee
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Record processing knowledge of dbAccess context Peregrine M. McGehee
