1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Problem starting StripTool
To: [email protected]
Date: Fri, 09 Apr 2004 15:24:28 +0900
Greetings,
I installed the ioc example as described in manual and succeded
in starting it as shown:
$../../bin/linux-x86/myexample st.cmd
epics> dbl
juHost:aiExample
juHost:aiExample1
juHost:aiExample2
juHost:aiExample3
juHost:calcExample
juHost:calcExample1
juHost:calcExample2
juHost:calcExample3
juHost:compressExample
juHost:subExample
juHost:xxxExample
epics>
What I'm trying to do now is to start Striptool. After Striptool
starts, I put the PV name into the upper window and connect.  Then
open the graph window.  The plot is empty.
It looks like PV name is not connected to StripTool.
When I issue command
$caget juHost:aiExample
Channel connect timed out: 'juHost:aiExample' not found.
$ca_test juHost:aiExample
Not Found juHost:aiExample
How do I fix this?
Thanks.
RE: Problem starting StripTool Jeff Hill
Prev: RE: Record processing knowledge of dbAccess context J. Frederick Bartlett
Next: Re: Record processing knowledge of dbAccess context Marty Kraimer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Record processing knowledge of dbAccess context Thompson, David H.
Next: RE: Problem starting StripTool Jeff Hill
