1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Bidirectional device support
To: "Liyu, Andrei" <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Tue, 13 Apr 2004 12:08:08 +0200
>>>>> "Andrei" == Andrei Liyu <Liyu> writes:
  > At second, bi-direction data is not need usually. Operator in LOCAL
  > (rack place) and REMOTE (from computer) sets new value and than sees it.
  > This is two operations, two values ...
  > Andrei.
I do not agree.
Scenario 1 (quite usual during commissioning):
  Some part of the machine is not working correctly. The device
  specialist goes there, switches everything local, optimizes until
  things are running.
  -> Without some bidirectional functionality you are left to write down
  all setpoints locally and hack them back into the system manually
  (quite error-prone) else you will lose beam as soon as you touch
  something.
Scenario 2 (usually with large "intelligent" sub-systems such as PLCs):
  No strict hierarchy, i.e. the EPICS system is just one client of the
  system and not the only master.
  -> Without some bidirectional functionality your EPICS screens will
  most likely not show the current status of the system. Touching setpoint
  sliders will most likely produce unwanted output jumps.
Scenario 3 (usually with small "intelligent" sub-systems such as
embedded device controllers):
  To create a "bumpless" reboot behaviour, the EPICS IOC should be able
  to read back the setpoints from the device. The collected values
  should end up in the same records that are used to control the
  device. (Else you still get bumps when you touch a slider.)
I think these are three good reasons why bi-directional behaviour is a
desireable feature. (I'm sure there are more...)
Ralph
RE: Bidirectional device support Ernest L. Williams Jr.
RE: Bidirectional device support Liyu, Andrei
Prev: RE: Bidirectional device support Robby Tanner
Next: RE: Bidirectional device support Ernest L. Williams Jr.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Bidirectional device support Liyu, Andrei
