Dirk,
> when I reboot a Motorola MVME5110, it takes ages (30 sec to be exact)
> until the vxWorks boot procedure starts. It takes another 30 seconds
> starting the loaded vxWorks kernel.
> Does anyone know what the board is doing in all that time?
> The MVME2306 have never waited for so long. Can I reduce that time?
I see exactly the same 30 second delays on MVME2700 when they are connected to certain models of Ethernet switches. I believe it is a problem with the 10/100 or full/half duplex negotiation. I have always been able to eliminate the problem by putting an Ethernet hub between those switches and the MVME2700. I believe that Andrew Johnson made changes to the bootrom code and BSP to try to fix the problem, but they did not help.
Mark Rivers
- Re: MVME5110 Dirk Zimoch
<2004>
2025
LabVIEW Channel Access Client Willem Blokland
<2004>
2025
