1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Initialising an ao record from a constant DOL
To: [email protected]
Date: Fri, 16 Apr 2004 16:11:19 +0100
I'm trying to initialise an analog output record
by putting a constant in the DOL field (see below).
But the VAL field gets set to zero rather than 100.
The record does process and outputs this zero.
I can work around this by Initialising from another record
using clsed loop mode but it does seem to be a bit of a cludge
(see commented out lines).
What am I doing wrong?
record(ao, "$(device):SETSIZE") {
    field(DESC, "Pump Size")
    field(DTYP, "ornlSerial")
    field(OUT,  "@digitel mpc size p=1 u=$(port) m=$(unit) p1=$(pump)")
    field(PINI, "YES")
    field(DOL,  "100.0")
#    field(DOL,  "$(device):INITSIZE")
#    field(OMSL, "closed_loop")
    field(EGU,  "l/s")
    field(DRVL, "0.0")
    field(DRVH, "1200.0")
    field(LOPR, "0.0")
    field(HOPR, "1200.0")
    field(PREC, "0")
record(ai, "$(device):INITSIZE") {
    field(VAL, "200.0")
Pete
mailto:[email protected]
phone:+44 (0)1925 603974
fax:    +44 (0)1925 603124
CLRC
Daresbury Laboratory
Keckwick Lane
Warrington
WA4 4AD
UK
RE: Initialising an ao record from a constant DOL Kim, Kukhee
Prev: Base R3.13.10 now available Andrew Johnson
Next: VDCT build 1249 available John Maclean
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Initialising an ao record from a constant DOL Kim, Kukhee
