1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Initialising an ao record from a constant DOL
To: [email protected]
Date: Fri, 23 Apr 2004 22:49:08 +0200
On Friday 23 April 2004 16:45, Andrew Johnson wrote:
> It looks to me like Pete's device support is returning a 0 from its
> init_record routine, when it should be returning a 2 as it hasn't properly
> set the RVAL field.
> I think that explains the problem and where the correct solution needs to
> go - in ornlSerial.  I'd suggest checking all of its output device
> supports which I believe should all do the same thing.
As i understood it, the device support returns 0 by purpose in order to enable
bumpless reboot and what Pete wants is to override this behavior with a
constant in DOL. As Bob said this is not possible at the moment. But i think
it should be possible to change the ao record support so that if DOL is
defined with some constant value then this value takes precedence over any
value return from the device support's init_record for bumpless reboot.
Ben
Re: Initialising an ao record from a constant DOL Andrew Johnson
Re: Initialising an ao record from a constant DOL Bob Dalesio
Prev: EPICS collaboration meeting presentations Bob Dalesio
Next: Vacancy at APS John Maclean
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Initialising an ao record from a constant DOL Andrew Johnson
Next: Re: Initialising an ao record from a constant DOL Andrew Johnson
