1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: gateway2_0_0_0Beta8 compile error.
To: <[email protected]>
Date: Wed, 28 Apr 2004 14:16:43 +0900
Hello All,
I need gateway applications for multiple IOC data collection.
I tried compile gateway2.0 under Linux and solaris, the error message was below:
The makefile using 3.13.x compatible config directory, not used 3.14.5 configure files.
Used gateway version:
gateway2_0_0_0Beta8 (13 Feb 2004) - needs R3.14.5 base.
[eioc-1:/home/users/kmha/epics/extensions/src/gateway]% make
make -C O.solarisGnu -f ../Makefile.Host T_A=solarisGnu BUILD_TYPE=Host install
make[1]: Entering directory `/home/users/kmha/epics/extensions/src/gateway/O.solarisGnu'
g++ -ansi -pedantic -Wtraditional   -DSOLARIS=8  -O  -Wall -Wmissing-prototypes -Woverlo
e-strings -Wconversion -Wstrict-prototypes -Wpointer-arith -Winline   -DSTAT_PVS -DRATE_
 -DCAS_DIAGNOSTICS -DHANDLE_EXCEPTIONS -DRESERVE_FOPEN_FD  -fPIC -D_REENTRANT  -DUNIX -D
  -I../../../include -I../../../include/os/solaris -I/home/users/kmha/epics/base/base-3.
aris -I/home/users/kmha/epics/base/base-3.13.9/include   -c   ../gateway.cc
../gateway.cc: In function `int startEverything(char*)':
../gateway.cc:548: warning: int format, pid_t arg (arg 4)
../gateway.cc: In function `int setEnv(const char*, const char*, char**)':
../gateway.cc:1356: `epicsEnvSet' undeclared (first use this function)
../gateway.cc:1356: (Each undeclared identifier is reported only once for each
   function it appears in.)
../gateway.cc: In function `void printRecentHistory()':
../gateway.cc:1404: warning: int format, pid_t arg (arg 3)
make[1]: *** [gateway.o] Error 1
make[1]: Leaving directory `/home/users/kmha/epics/extensions/src/gateway/O.solarisGnu'
make: *** [install.solarisGnu] Error 2
---------------- error Message begin :-------------------------------------------------------------
Kiman,
PLS Control and taskforce team
Prev: Re: Initialising an ao record from a constant DOL Andrew Johnson
Next: Re: gateway2_0_0_0Beta8 compile error. Kenneth Evans, Jr.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Vacancy at APS John Maclean
