1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: MVME5110
To: TECHTALK <[email protected]>
Date: Fri, 30 Apr 2004 14:49:58 +0200
Dirk Zimoch wrote:
Hi all,
when I reboot a Motorola MVME5110, it takes ages (30 sec to be exact) until the vxWorks boot procedure starts. It takes another 30 seconds starting the loaded vxWorks kernel.
Does anyone know what the board is doing in all that time? The MVME2306 have never waited for so long. Can I reduce that time?
Dirk
After adding a lot of debug messages, I found where so much time is spent. As some of you suspected and I doubted, the network interface is involved but in an unexpected way. Memory setup also has a part in consuming boot time.
I had enabled the second network interface by defining INCLUDE_SECONDARY_ENET in config.h. Unfortunately, the result was that fei82557EndLoad() in fei82557End.c tried auto negotiation on the unconnected secondary interface for 20 seconds. It did so in the boot loader and again at vxWorks startup.
To shorten boot time, I have undefined INCLUDE_SECONDARY_ENET in bootConfig.c (I don't want to boot from that interface). I've also hacked fei82557End.c not to try auto negotiation if it can't find a carrier signal and not to retry if the first attempt failed. I found that I still could use the secondary interface at 100MBS when I connect it later.
How the time is spent now:
It takes 5 seconds until usrInit() is called.
For each enabled network interface it takes 3 seconds to read the 82557 EEPROM.
Auto negotiation needs 1.5 seconds if the network interface is connected.
It still needs about 10 seconds after power on or reset before the first message is printed. I hope when I use BATs instead of PTEs, I can save another 5 seconds or so.
Thanks to all for the helpful suggestions.
Dirk
Dr. Dirk Zimoch
Swiss Light Source
Paul Scherrer Institut
Computing and Controls
phone +41 56 310 5182
fax   +41 56 310 4413
LabVIEW Channel Access Client Willem Blokland
MVME5110 Dirk Zimoch
Prev: mpfosi release 2-6 Marty Kraimer
Next: LabVIEW Channel Access Client Willem Blokland
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: Re: MVME5110 Craig Walther
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
