1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: RE: RE: gateway2_0_0_0Beta8 compile error
Date: Mon, 10 May 2004 02:58:58 +0900
Hello all.
I tried to replacement old config and configre directoris to last vertions.
The previous my compile problem was config and configure files used old versions.
And I compile gateway2.0 with new configure files under Windows but i found compile errors.
I will be testing to under Linux and Solaris when i return to PLS.
HOST : Win2K
and Visual C 6.0
base 3.14.5
---- error ---
C:\epics\extensions\src\gateway>make
make -C O.win32-x86 -f ../Makefile.Host T_A=win32-x86 BUILD_TYPE=Host install
make[1]: Entering directory `/cygdrive/c/epics/extensions/src/gateway/O.win32-x86'
cl /GX /GR /nologo /D__STDC__=0 /Ox /W3 -DSTAT_PVS -DRATE_STATS -DCONTROL_PVS -DCAS_DIAGNOSTICS -DHANDLE_EXCEPTIO
NS /DWIN32 /D_WINDOWS /MD -I. -I.. -I../../../include/os/WIN32 -I../../../include -Ic://epics/base-3.14.5/include/
os/WIN32 -Ic://epics/base-3.14.5/include -c /Tp ../gateAsCa.cc
gateAsCa.cc
../gateAsCa.cc(43) : error C2375: 'connectCB' : redefinition; different linkage
../gateAsCa.cc(38) : see declaration of 'connectCB'
../gateAsCa.cc(66) : error C2375: 'eventCB' : redefinition; different linkage
../gateAsCa.cc(39) : see declaration of 'eventCB'
make[1]: *** [gateAsCa.obj] Error 2
make[1]: Leaving directory `/cygdrive/c/epics/extensions/src/gateway/O.win32-x86'
make: *** [install.win32-x86] Error 2
Kiman,
PLS Control Group.
To: "Tech-Talk"
Subject: Re: gateway2_0_0_0Beta8 compile error.
Date: Wed, 28 Apr 2004 09:39:18 -0500
Kiman,
Based on your output, the base you are using is apparently 3.13
(solarisGnu), and you are getting 3.13.9 headers. Gateway 2.0 requires
3.14.5 or later.
First, set COMPAT_TOOLS_313=YES in base/configure/CONFIG_SITE and then
do a make in base/config/tools to install the necessary Perl scripts. This
is necessary starting with 3.14.5.
Second, set EPICS_BASE to your 3.14.5 base in
extensions/config/RELEASE.
The Gateway should build properly on solaris-sparc, linux-x86, and
win32-x86. I do these three platforms regularly.
-Ken
RE: gateway2_0_0_0Beta8 compile error Kenneth Evans, Jr.
Prev: CapFast Dr. Chong Lee
Next: RE: gateway2_0_0_0Beta8 compile error Kenneth Evans, Jr.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
