As the subject says I am attempting to build R3.13 extensions with R3.14.5. I am following the instructions at http://www.aps.anl.gov/epics/modules/base/R3-14/5-docs/BuildingR3.13ExtensionsWithR3.14.html with no success. Here are the error messages. [savage@d0ol30 extensions]$ gmake stat(): No such file or directory at ./config/fullPathName.pl line 6 stat(): No such file or directory at ./config/fullPathName.pl line 6 gmake -C configure buildInstall gmake[1]: Entering directory `/mnt/nobackup/home/savage/extensions/configure' gmake -C O.linux-x86 -f ../Makefile TOP=../.. T_A=linux-x86 buildInstall gmake[2]: Entering directory `/mnt/nobackup/home/savage/extensions/configure/O.l inux-x86' gmake[2]: Nothing to be done for `buildInstall'. gmake[2]: Leaving directory `/mnt/nobackup/home/savage/extensions/configure/O.li nux-x86' gmake[1]: Leaving directory `/mnt/nobackup/home/savage/extensions/configure' gmake -C src buildInstall stat(): No such file or directory at ../config/fullPathName.pl line 6 stat(): No such file or directory at ../config/fullPathName.pl line 6 gmake[1]: Entering directory `/mnt/nobackup/home/savage/extensions/src' gmake -C alh buildInstall stat(): No such file or directory at ../../config/fullPathName.pl line 6 stat(): No such file or directory at ../../config/fullPathName.pl line 6 gmake[2]: Entering directory `/mnt/nobackup/home/savage/extensions/src/alh' perl /d0usr/products/epics/NULL/base-3.14.5/bin/linux-x86/makeMakefile.pl O.linu x-x86 Host Can't open perl script "/d0usr/products/epics/NULL/base-3.14.5/bin/linux-x86/mak eMakefile.pl": No such file or directory gmake[2]: *** [O.linux-x86] Error 2 gmake[2]: Leaving directory `/mnt/nobackup/home/savage/extensions/src/alh' gmake[1]: *** [alh.buildInstall] Error 2 gmake[1]: Leaving directory `/mnt/nobackup/home/savage/extensions/src' gmake: *** [src.buildInstall] Error 2
[savage@d0ol30 extensions]$ cat config/RELEASE #RELEASE Location of external products # EPICS_EXTENSIONS=$(TOP) #EPICS_BASE=/usr/local/iocapps/R3.13.9/support/base/3-13-9-asd1 #EPICS_BASE=/usr/local/iocapps/R3.14.5/support/base/3-14-5-asd1 EPICS_BASE=/d0usr/products/epics/NULL/base-3.14.5 The file ./config/fullPathName.pl does indeed exists in the extensions area. The makeMakefile.pl was not installed in the base-3.14.5 build. Any suggestions? I'm going to try and use the makeBaseExt.pl script to create a new extensions area. Thanks for the support. Geoff
ANJ, 10 Aug 2010 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
