1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: R3.14.5 and Fedora Core 2
To: john sinclair <[email protected]>
Cc: tech talk <[email protected]>
Date: Wed, 26 May 2004 18:40:48 -0400
Did you get the latest version of StripTool from the APS website?
Everything compiles okay for us under Fedora Core2 but there is a
channel access bug in R3.14.5 that crashes StripTool at run time.
The bug has been fix in the upstream R3.14 branch.
Send me a snippet of your compile error message.
Ernest
On Wed, 2004-05-26 at 17:57, john sinclair wrote:
> For Fedora Core 2:
>   R3.14.5 base builds fine.
>   Striptool fails. Everything compiles and then gmake issues this command
>     cc   StripTool.o   -o StripTool
>   which of course results in zillions of undefined references.
> What gives?
> (I'm using the latest extensions config/configure stuff)
Ernest L. Williams Jr. <[email protected]>
R3.14.5 and Fedora Core 2 john sinclair
Prev: R3.14.5 and Fedora Core 2 john sinclair
Next: Problems w/ VxWorks Global Variable Device Records Susanna Jacobson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
