1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RTEMSfor MVME5500
To: <[email protected]>
Cc: <[email protected]>, <[email protected]>
Date: Fri, 16 Jul 2004 18:09:55 +0900
 Hello Kate,
Anyone have to tried compile RTEMS for MVME5500?
Our Control staffs who Mr OH is recently trying to compile RTEM for
MVME5500.
But he reported to me some compile error messages
Used : RTEMS-4.6.0pre1
      Gcc3.2.1
He fallowed form your README files;
http://www.nsls.bnl.gov/organization/UserScience/Detectors/Software/README.t
xt
To build cexp :
0) cd cexp-1.4.beta
1) mkdir build_linux_ppc-rtems
2) cd build_linux_ppc-rtems
3)
..../configure --prefix=/opt/rtems/ppc-rtems --host=ppc-rtems --with-multisubd
ir=m750 --disable-nls
To build xsyms :
0) cd cexp-1.4.beta
1) mkdir build-xsyms
2) cd build-xsyms
3)  ../configure --target=ppc-rtems
---- Passed compile successfully -------
But the compile error is occurs this step;
To build rtems5500-cexp.bin and rtems5500-cexp.sym :
0) cd RTEMS5500-GeSys_2.1.beta
2) make
 ldep/ldep.c:659:2: warning: #warning TODO weak symbols
Warning: Symbol without object file??
-> substituting symbol file name, using 'startfiles.o'...
(o-optimize/startfiles.nm/line 1)
Warning: type mismatch between multiply defined symbols
         __deregister_frame_info: known as T, is now w
         __register_frame_info: known as T, is now w
         environ: known as G, is now B
Warning: Object
'/work/rtems/rtems-ppc/lib/gcc-lib/ppc-rtems/3.2.1/../../../../ppc-rtems/lib
/libbfd.a[archive.o]' couldn't be removed; probably it's needed by the
application
Warning: Object
/libbfd.a[archures.o]' couldn't be removed; probably it's needed by the
application
Warning: Object
/libbfd.a[bfd.o]'
Warning: Object
/libiberty.a[xexit.o]' couldn't be removed; probably it's needed by the
application
Warning: Object
/libiberty.a[xmalloc.o]' couldn't be removed; probably it's needed by the
application
Warning: Object
/libiberty.a[xstrerror.o]' couldn't be removed; probably it's needed by the
application
Warning: Object 'librtemscpu.a[dummy.o]' couldn't be removed; probably it's
needed by the application
Warning: Object
application
Object
/librtemsbsp.a[ftpd.o]' not found!
--- end of error message ---
When are you going to release the BSP source code for MVME5500?
>2) Please copy the rtems5500-cexp.bin, rtems5500-cexp.sym and st.sys
Please could you send to me 3 of binary files for booting from MVME5500.
Kiman Ha,
PLS Control and taskforce team.
Re: RTEMSfor MVME5500 Kate Feng
Prev: Re: GreenSpring TIP810 CANbus system Ralph Lange
Next: RE: RTEMSfor MVME5500 Luchini, Kristi
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: GreenSpring TIP810 CANbus system Allison, Stephanie
Next: Re: RTEMSfor MVME5500 Kate Feng
