1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: GreenSpring TIP810 CANbus system
To: EPICS tech-talk <[email protected]>
Date: Fri, 16 Jul 2004 16:18:00 +0200
At DESY we are using the TIP810 and a compatible IP module built by IHEP in Russia.
In addition we are using DIN Rail PC's with a built in CAN interface based on the Intel 82527 chip.
http://www.powerbridge.de/daten/p_ipc-system/pc6/pc6.htm
All of them with EPICS support based on Andrews IPAC driver with our CAN driver below.
-Matthias
John Maclean wrote:
Bill,
At APS we've just moved to VIPC626 IP carriers. These are software compatible with the previous VIPC616 model which has EPICS support. The VIPC626 are a lot easier to configure I believe, no wire wrapping required.
I've used the TIP810 modules with Andrew Johnsons driver code on a couple of projects and have found them to be absolutely rock solid. IIRC they use an early generation of CAN controller chip. Later generations of CAN controller mainly do more to offload processing from CPU. This is probably not an issue unless you have many heavily loaded CAN links coming into your ioc. I don't think 3 will be a problem, but it will depend on the amount of bus traffic you have of course. Gemini have 8 buses in one ioc. It almost certainly isn't an issue if you use a PPC.
HTH,
John.
[email protected] wrote:
Greetings,
I am trying to duplicate a CANbus system here at the STAR experiment. We have
two distinct modules/controllers and chains. We want to split off some Wiener
crates to form a third (to make life easier on some subsytem detectors). It
would also give us a backup option!
We presently have two GreenSpring TIP810, which are VIP610 carrier boards. (6U
VME boards with 4IP and front I/O ribbon connections). We use two processors,
one is a 162, and the other 167, otherwise things are pretty identical, except
for the numbers and kinds of Wiener crates on each chain. For these systems we
run an old version of VxWorks 5.2 and an old version of EPICS 3.12-LBL.4
I did get some information from TEWs regarding the TIP810-10 which replaces the Greenspring 810, and am anxious to order. I wanted to get some expert advice
first. Would there be significant benefits to trying a "new" approach rather than
duplicate. This all seems like a quick and easy option but perhaps there are
others that we should be considering? (For example other carrier boards, the
TIP816 etc.)
Thanks in advance
Bill Waggoner
STAR
Brookhaven National Lab
-- ------------------------------------------------------------------------ Matthias Clausen Cryogenic Controls Group(MKS-2) phone: +49-40-8998-3256 Deutsches Elektronen Synchrotron fax: +49-40-8994-3256 Notkestr. 85 e-mail: [email protected] 22607 Hamburg WWW-MKS2.desy.de Germany ------------------------------------------------------------------------
GreenSpring TIP810 CANbus system wtw00992
Re: GreenSpring TIP810 CANbus system John Maclean
Prev: Re: GreenSpring TIP810 CANbus system John Maclean
Next: RE: RTEMSfor MVME5500 Elder Matias
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: GreenSpring TIP810 CANbus system Allison, Stephanie
