1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Proglem doing CA calls after catching a signal
To: Eric Norum <[email protected]>
Cc: Robert Soliday <[email protected]>, tech-talk <[email protected]>
Date: Wed, 21 Jul 2004 09:33:44 -0700
To be honest, I dont know if it's safe for a signal handler to join a thread context. There's at least one possible race condition in this case: the signal handler could execute after ca_task_exit() has been called. What other race conditions are you thinking about?
I'm sure Jeff will weigh in when he gets back.
Chris Timossi
Eric Norum wrote:
Robert Soliday wrote:
Thanks, this solved my problem.
--Bob
Chris Timossi wrote:
Robert,
I believe that you should replace ca_task_initialize with
 > ca_context_create(ca_enable_preemptive_callback) in main. Then in the
 > interrupt handler, you can call ca_current_context() to get the
 > current context and finally join that context with
 > ca_attach_context().
Are you sure that this is safe? I suspect that calling these functions from a signal handler is going to introduce all sorts of race conditions.
Jeff -- can you confirm/deny my suspicions?
Re: Proglem doing CA calls after catching a signal Eric Norum
Proglem doing CA calls after catching a signal Robert Soliday
Re: Proglem doing CA calls after catching a signal Robert Soliday
Prev: Re: Proglem doing CA calls after catching a signal Eric Norum
Next: CGI Export wtw00992
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Proglem doing CA calls after catching a signal Eric Norum
