1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Re: RTEMSfor MVME5500
To: "KateFeng" <[email protected]>, [email protected]
Cc: [email protected], [email protected]
Date: Tue, 27 Jul 2004 23:16:27 +0900
Hello Kate,
Mr OH was added on what you attached Makefile.inc and mvme5500.cfg files.
Tried again to make utility after cleared before error messages, but the other error messages are
¡°compiled for a little endian system and target is big endian¡±.
Error Messqges:
File in wrong format: failed to merge target specific data of file /opt/rtems/lib/gcc-lib/pp
c-rtems/3.2.1/../../../../ppc-rtems/lib/libbfd.a(archive.o)
/opt/rtems/lib/gcc-lib/ppc-rtems/3.2.1/../../../../ppc-rtems/bin/ld: /opt/rtems/lib/gcc-lib/
ppc-rtems/3.2.1/../../../../ppc-rtems/lib/libbfd.a(archures.o): compiled for a little endian
ppc-rtems/3.2.1/../../../../ppc-rtems/lib/libbfd.a(bfd.o): compiled for a little endian syst
c-rtems/3.2.1/../../../../ppc-rtems/lib/libbfd.a(opncls.o)
ppc-rtems/3.2.1/../../../../ppc-rtems/lib/libbfd.a(reloc.o): compiled for a little endian sy
He used patch files version are below:
binutils-2.13.2.1
gcc-3.2.1
rtems-ss-20030128
Did you used different of patch versions for MVME5500 target?
Sorry for much a question.
Kind regards,
Kiman.
PLS Control and taskforce team.
> -----Original message-----
> From: "KateFeng"
> To: [email protected]
> Cc: [email protected],[email protected]
> Date: 07/27/2004(Tue)02:33
> Subject: Re: RTEMSfor MVME5500
> [email protected] wrote:
> > Hello Kate,
> > >RTEMS-4.6.0 is better than  RTEMS-4.6.0pre#.   RTEMS-4.6.0 has
> > >PowerPC patches  for RTEMS-4.6.0pre#.
> > He tried to recompile RTEMS-4.6.0 kernels and GeSys_2.1beta codes.
> > All passed before step what for build cexp : and xsyms :
> > >To build rtems5500-cexp.bin and rtems5500-cexp.sym :
> > >0) cd RTEMS5500-GeSys_2.1.beta
> > >1) make
> > Did you used bspcheck commands at Makefile line 142.
> Till Straumann wrote the  original Makefile, which I  added the
> support for the mvme5500.   It appears to me bspcheck
> is not a command.  Searching  the Makefile,  I got
> two lines regarding  bspcheck.
> bspcheck: $(if $(filter $(RTEMS_BSP_FAMILY),pc386 mvme5500 motorola_powerpc
> svgm),,bspfail)
> and
> all: bspcheck libnms ${ARCH} $(SRCS) $(PGMS)
> > But when i type make commands after other error messages from Makefile line 142..
> > What is missing ?
> > root@rtemsdev RTEMS5500-GeSys_2.1.beta]# make
> > Makefile:142: *** GeSys has not been ported/tested on this BSP (mvme5500) yet.
> > Makefile: 142 Line :
> I could not duplicate your error message.   What message did you
> get before those error message came out ?
> Make sure you have  environment variable :
> RTEMS_MAKEFILE_PATH=/opt/rtems/ppc-rtems/mvme5500
> However, I do find out that you are missing
> /opt/rtems/make/custom/mvme5500.cfg (attached).
> Also,  one has to modify the  RTEMS5500-GeSys_2.1.beta/config
> files  (e.g. libbfd.excl, libiberty.excl, and  libopcodes.excl)
> to change the path from /opt/rtems3 to its own defined directory.
> The same as  the ppc-rtems/mvme5500/Makefile.inc file.
> Regards,
> Kate
Re: RTEMSfor MVME5500 Kate Feng
Prev: RE: Base on windows Mark Rivers
Next: Re: RTEMSfor MVME5500 Kate Feng
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: RTEMSfor MVME5500 Kate Feng
