1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Base on windows
To: [email protected]
Date: Wed, 28 Jul 2004 07:09:47 +0200
Thanks to everyone who replied. I was using 3.14.4 - but on 3.14.6 with
cygwin, base built without problems as reported.
On Tue, 2004-07-27 at 16:55, Janet Anderson wrote:
> Steven Hunt wrote:
> > Does anyone have the configs to build base 3.14.x on windows running
> > cygwin/gcc ?
> > Steve Hunt
> The cygwin config files already exist in R3.14 base. You should be able to
> build R3.14.6 base and EPICS extensions after executing the following cygwin.bat
> file (with local changes made). If you have an earlier version of R3.14
> base change the EPICS_HOST_ARCH value from cygwin-x86 to win32-x86-cygwin.
> REM
> REM    --------------- WINDOWS ---------------------------
> REM    ----- WIN95 -----
> REM set PATH=C:\WINDOWS;C:\WINDOWS\COMMAND
> REM    ----- WINNT -----
> set PATH=C:\WINNT;C:\WINNT\SYSTEM32
> REM    --------------- GNU make (use cygwin make ) ----------------
> REM    cygwin contains tk/tcl, vim, perl, and many unix tools
> set PATH=%PATH%;c:\cygwin\bin
> REM    --------------- EPICS -----------------------------
> REM    R3.14 requirements
> set EPICS_HOST_ARCH=cygwin-x86
> set PATH=%PATH%;G:\epics\base_R3_14\bin\%EPICS_HOST_ARCH%
> set PATH=%PATH%;G:\epics\extensions\bin\%EPICS_HOST_ARCH%
> REM    ---------------- EPICS tools ----------------------
> REM HOST_ARCH needed for Makefile.Host builds
> set HOST_ARCH=cygwin32
RE: Base on windows Jeff Hill
Base on windows Steven Hunt
Prev: Re: Base on windows guobao shen
Next: RE: Base on windows Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
