1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: How to pass constant string into a genSub or sub record
To: Susanna Jacobson <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 5 Aug 2004 04:19:38 -0600 (MDT)
Hi Susanna,
I encountered the same issue when designing genSub records
for the LEDA Run Permit system back in 1998 - please see my
tech-talk posting, which includes a code listing, at:
http://www.aps.anl.gov/epics/tech-talk/1998/msg00850.php
Best regards,
    Peregrine
On Thu, 5 Aug 2004, Susanna Jacobson wrote:
> Hi folks,
> This concerns subroutine and genSub records in EPICS R3.13.4.
> I need to pass a string into a subroutine or general subroutine
> record at initialization time because I don't want to fix the information
> in the code for the record's init and process routines.
> So I assigned the string to an input link in the .db file, just as one
> would pass a numeric constant.  However, the record interprets the string
> as a PV name, which generates a lot of pointless network traffic as link
> processing looks for a record with that name.
> Is there a way to tell the record that the string is a constant and
> not a PV name?  Do I have to use a string record to hold the string
> and use the input link as a link?  Or is there another, better way to
> do it?
> 	Thanks in advance,
> 	Susanna
> Susanna Jacobson                MS 10-110
> [email protected]              Lawrence Berkeley National Laboratory
> VOICE:  (510) 486-7801          1 Cyclotron Road
> FAX:    (510) 486-7374          Berkeley, CA 94720
Peregrine M. McGehee	Department of Astronomy
New Mexico State University, Las Cruces, New Mexico
How to pass constant string into a genSub or sub record Susanna Jacobson
Prev: How to pass constant string into a genSub or sub record Susanna Jacobson
Next: CA Gateway problem Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
