1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Anyone have Channel Access for Perl going?
To: [email protected], [email protected]
Cc: [email protected]
Date: Thu, 12 Aug 2004 08:06:29 -0500 (CDT)
John:
> Ernest,
> I haven't used Perl with Channel Access under R3.14.X.
> However you may be interested to know that under 3.13 I found execution
> was *much* quicker just calling the systems caget and caput programs in
> back ticks rather than using one of the Perl-CA packages. It all depends
> how much CA functionality you want I guess.
> John.
While it may be true for simple caput and caget, if you were to use any other
calls and also it all depends on how you set you caretry etc....
Long time ago I had benchmrked it and found it to use the perl ecza and thats
the reason I created it!
 In addition if you want any of the other 23 odd functions from EZCA you have
it!
mohan
Mohan Ramanathan                     Critical Component Sys. Mgr.
[email protected]                    Advanced Photon Source
(630)-252-3773                       Argonne National Laboratory
(630)-252-7187 (FAX)                 Argonne, IL 60439
Prev: Re: Anyone have Channel Access for Perl going? Mohan Ramanathan
Next: EPICS drivers for DAC/ ADC Industry Packs on a PCI carrier board Dorothea Wehler
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
