1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Industry Pack support under RTEMS available?
To: "'Dorothea Wehler'" <[email protected]>, EPICS TechTalk <[email protected]>
Date: Tue, 17 Aug 2004 09:20:04 -0700
Hello Dorothea,
> may I ask once again for drivers: Is someone using  carrier boards on
> VME-systems running RTEMS together with  A/D- and D/A-converter
> Industry Packs?
At SSRL/SPEAR, we are using Andrew Johnson's IPAC support version 2.7a converted to OSI/RTEMS on base 3.14.6.  I have sent the cvs differences to Andrew for his consideration and can send them to you too - let me know.
We are using the Acromag AVME9670 IP carrier board and the following IP modules:
TEWS TIP810 CANbus (part of the IPAC 2.7a package)
Acromag IP440 Digital Input
Acromag IP445 Digital Output
Acromag IP470 Digital I/O
For the IP440 and 445, we use the XYCOM 2440 and 2445 support from Andy Foster converted to 3.14.6/OSI/RTEMS.  I have sent the changes back to Andy - the modified source is also here:
ftp://ftp.slac.stanford.edu/groups/controls/soft/epics/xycomIpac.tar.gz
The IP470 software was developed in-house (very similar to the IP445) and is here:
ftp://ftp.slac.stanford.edu/groups/controls/soft/epics/acromagIpac.tar.gz
The support assumes that you have developed a base/src/libCom/osi/os/RTEMS/devLibOSD.c for your target.  The devLibOSD.c that is delivered with base 3.14.6 only supports PPC mpc750.  There's been discussion offline of tech-talk about the best way to have a more generic RTEMS devLib but I don't think that discussion came to any conclusion.
Till Straumann also has Hytec 8002 carrier and Hytec 8401 IP module software (originally from SLS?) converted to 3.14.1/RTEMS but I don't know the status of that software.  It's not used in production here.  I can send you what we have but Till should say something about its pedigree.
Stephanie Allison
Re: Industry Pack support under RTEMS available? Kate Feng
Prev: Re: Industry Pack support under RTEMS available? Kate Feng
Next: Re: Industry Pack support under RTEMS available? Kate Feng
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
