1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: EPICS waveform output record
To: EPICS tech-talk <[email protected]>
Date: Wed, 22 Sep 2004 17:21:01 -0400 (EDT)
I am writing support for an arbitrary waveform generator (Joerger Model
VDACM 8 channel, 16-bit, 100kHz, waveform generator with 32k memory per
channel).
Is there an EPICS record which is appropriate for such a device? The aao
record seems like a possibility, but a search of tech-talk archives from
1996 and 2000 revealed a number of problems with this record which don't
appear to have been incorporated into later releases (looking at
aaoRecord.c from R3.13.10).
The waveformRecord is close, but is designed for readback, not output like
I need for this device. The gensub record may be a way to deal with it, if
necessary.
Is anyone using a similar device, and if so, what record are you using?
Also, any suggestions on user interface for loading and modifying
waveforms?
Steve Hartman
[email protected] || 919-660-2650
Duke Free Electron Laser Laboratory
Re: EPICS waveform output record Carl Lionberger
Prev: Re: ca_repeater bug (probably observable only on RTEMS) Till Straumann
Next: RE: EPICS waveform output record Rogind, Debbie
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Prev: building Interviews for gdct under solaris and gcc Dale L. Brewe
Next: Re: EPICS waveform output record Carl Lionberger
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
