Hello again Liyu,
>From here it appears that you have two options:
1) Use a "makefile" project in visual C++ and build using the EPICS build
system to create your server. With this approach you don't need to be
intimately familiar with the MS compiler's build options.
2) Otherwise, you can run the EPICS build, observe what options are being
used, and then configure your visual C++ project to use the same options.
You will need to translate between the menu options you see in the visual
C++ GUI and the low level options used by the compiler.
> exAsyncPV.obj : error LNK2001: unresolved external symbol "private:
> static class epicsMutex * gdd::pGlobalMutex"
> (?pGlobalMutex@gdd@@0PAVepicsMutex@@A)
This might occur because the build options you are using are not compatible
with the libraries created when building EPICS base. In particular, you will
need to specify options for thread safe library interfaces, the same
debugging options, and the same DLL vs object library choices for the basic
runtime support as were used to build EPICS base. Alternatively, simply
omitting the gdd library from the link line could be the sole cause of
trouble.
Jeff
> -----Original Message-----
> From: Liyu, Andrei [mailto:[email protected]]
> Sent: Monday, October 04, 2004 2:09 PM
> To: [email protected]
> Subject: RE: portable server
> I have used Andrew's advice, created Portable server and built it. It
> works. It is like I did it one year ago but forget. Thank you - Andrew.
> But then I decide to collect MVC++ project from that example. I could
> compile but couldn't do linking. I have message like this
> >From another side
> dumpbin gdd.lib /EXPORTS ->
> ?pGlobalMutex@gdd@@0PAVepicsMutex@@A (private: static
> class epicsMutex * gdd::pGlobalMutex)
> View file : __imp_?pGlobalMutex@gdd@@0PAVepicsMutex@@A
> Has anybody suggestion?
> Thanks, Andrei.
> P.s. I know how I could work from MVC environment with make.
> From: Andrew Johnson [mailto:[email protected]]
> Sent: Friday, October 01, 2004 7:12 PM
> To: Liyu, Andrei
> Cc: [email protected]
> Subject: Re: portable server
> Liyu, Andrei wrote:
> > Hi,
> > 1. I would like to write portable server. There is tutorial of
> portable
> > server. It has example. But example has mistakes and it is like Epics
> > base h file were changed too. I spent some time to build it but hasn't
> > success.
> > Has anybody working code of portable server from tutorial or code of
> the
> > simplest another portable server? I have 3.14.4, Windows XP, MVC++
> 6.0.
> There is an portable server template provided for use with
> makeBaseApp.pl
> in your version of Base, which should give you a working example. To
> create an application to try out, run makeBaseApp and specify
> caServerApp
> as the template type - something like this, but you'll probably have to
> modify the command somewhat to get it to run on Windows (which I can't
> help you with as I only use Unix):
> mkdir example
> cd example
> perl /path/to/base/bin/win32-x86/makeBaseApp.pl -t caServerApp server
> This will create the necessary files to make your own server, which you
> can then compile, edit and experiment with. Be sure to read the README
> text file in the serverApp subdirectory for more information about the
> server.
> - Andrew
> Dear God, I didn't think orange went with purple until I saw
> the sunset you made last night. That was really cool. - Caro
- RE: portable server Liyu, Andrei
Long Error Message Owens, PH (Peter)
<2004>
<2004>
