Just to be crystal-clear, it sounds (to me) like the
consensus position is that CA should propagate, communicate,
and otherwise handle NaN (and INF) like any other floating
point value.
The places where such values should be rejected as
inappropriate are at the client-side ("above" CA), or in
device support. In addition, the aoRecord (but no other
output records) will be modified so that it can optionally
recognize NaN and suppress executing device support "write_ao()"
function when NaN is encountered (essentially as a convenience
for existing device support modules which do not check for NaN
themselves). Is that right?
Blocking inappropriate values at the client side is not
fool-proof, and not just for NaN. I am sure that the SNS
save/restore program sent NaN due to design or programming error,
not intentionally. Design/programming errors can result in other
inappropriate values to be sent as well (e.g. improperly initialized
memory). NaN, however, has the unique property that it is easily
recognizable as highly likely to be inappropriate. Even so, the
consensus seems to be that suppressing the transmission of NaN via
CA is too restrictive, or may "break" existing applications.
The ramification of this is that if a NaN (or other
inappropriate value) is sent to a PV, it will make it at least as
far as the record before being flagged as inappropriate. I think
this means that the previous "good" value is obscured. Even though
the NaN is "trapped", it still may be necessary to re-send the
previous value in order for the system to operate properly.
Is that right? In the case of SNS, that would mean using some
older save/restore file that did have an appropriate value for
the PV in question.
- Re: Not-a-number (nan) issues Andrew Johnson
RE: double defenition in Epics Jeff Hill
RE: double defenition in Epics Liyu, Andrei
<2004>
2025
<2004>
2025
