1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: list of *all* EPICS records
To: <[email protected]>
Date: Fri, 15 Oct 2004 08:49:34 -0700
Hi Tim,
> In particular, if you thought about writing a new record type but didn't,
> or if you know of a record type that's no longer used (e.g., superceded by
> some new capability in base, capability merged into some other record,
> function moved to device support, author got tired of maintaining it, was
> a bad idea from the start, or whatever) your experience might be just the
> thing some new developer needs to be hammered with.
Here are some that are used at SLAC and SPEAR:
swfRecord - scaled waveform record from BESSY, same as waveform but with raw offset and vertical scale factor and offset.  Used in reading scopes.
wftimeRecord - waveform with both time and Y, assumes both are double, for input waveforms only.  PREC, EGU, HOPR, LOPR provided for both time and Y.  ESLO and EOFF provided for Y.  NORD monitor goes off when changed (unlike waveform which I think is a bug).  Used in reading time/value arrays from Keithley DVMs.
sSub - special subroutine, same as sub except with 26 inputs (A to Z)
One custom record per six custom RF VXI modules which are loaded with features and have very large address maps plus DSP interfaces - each record can be thought of as a combination of many ai/ao/bi/bo/sub/seq/waveform records where the bulk of the processing is done in device support.  These records are monsters but I think new people assigned to maintain them come up to speed more quickly - it's easier to match the hardware documentation and address maps with the software.
Stephanie Allison
Re: list of *all* EPICS records Till Straumann
Re: list of *all* EPICS records -- summary (long) Tim Mooney
Prev: Re: list of *all* EPICS records Mohan Ramanathan
Next: Re: list of *all* EPICS records Till Straumann
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
