1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: list of *all* EPICS records
To: [email protected]
Cc: "'[email protected]'" <[email protected]>, <[email protected]>, <[email protected]>
Date: Mon, 18 Oct 2004 12:44:27 +0100 (BST)
Hi Tim,
There are several other custom records in use at Gemini:
deviceControl:   For control of the OMS-58 and the older OMS-8/44.
                 Understands Gemini's command/action protocol.
assemblyControl: For control of a collection of "devices" that
                 must work together to perform a specific instrument
                 function. Where device can be thought of as a single
                 moving component. Understands Gemini's
                 command/action protocol and has built in simulation
                 and debugging modes.
coordinateMotionControl:
                 Supports simultaneous moves along 3 axes
                 for DC servo motors and steppermotors
                 controlled by an OMS-58. Understands Gemini's
cmdTimeout:      Checks if a command reaches a subsystem and sets
                 an appropriate error string if a timeout occurs.
                 Based on Gemini's command/action protocol.
load:            Supports the uploading and downloading of
                 command strings through the PMAC mailbox registers.
lutin:           Lookup table input record. Converts 4 input values
                 into a character string.
lutout:          Lookup table output record. Converts a character string
                 tag into 4 output values.
status:          Like an "mbbiDirect" but for 32-bits.
Cheers,
Andy
Observatory Sciences Limited    Email: [email protected]
William James House             Tel: 44 - (0)1223 - 508259
Cowley Road                     Fax: 44 - (0)1223 - 508258
Cambridge, CB4 0WX, UK          http://www.observatorysciences.co.uk
RE: list of *all* EPICS records Kevin Tsubota
Prev: Re: linking iocCore lib error Till Straumann
Next: Re: list of *all* EPICS records -- summary (long) Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: list of *all* EPICS records Kevin Tsubota
Next: Re: list of *all* EPICS records Siddons, David
