These records use the device support CAEN_IO for CAEN SY527 HV modules. I can set the values via medm or ca_test. When I use burtwb the values are not touched at all. The burtwb logfile indicates all is well, connected to all channels, all values written. I enabled the process printout on one of these records, it gives 1 message when I change the PV with medm, it gives 7 (why?) messages when used with ca_test and NONE with burtwb. burtrb can read the values without any problem. There is no access security problem, no network problem. Other ao-records with different device support do work with burtwb. EPICS base is 3.13..0, burt version?? from Aug 2002 Any clue how to debug this? Burkhard Kolb HADES @ GSI Darmstadt
ANJ, 10 Aug 2010 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
