1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Multiple IOC's in a crate?
To: "'W T Meyer'" <[email protected]>, <[email protected]>
Date: Tue, 9 Nov 2004 19:20:46 -0500
	It is absolutely possibly to run multiple VxWorks systems
in a VME crate. VMEbus is designed as a multi-master bus.
One of the issues that crops up is that each interrupt level
can only be "steered" to one of the masters. I.e. if you have
two I/O modules which require interrupt service, and you'd like
each VxWorks system to service one of the I/O modules, then
each module will have to use a different VMEbus interrupt level,
and each VxWorks system should only enable "sensitivity" to one
of the two interrupt levels.
	There are also considerations of bus arbitration for
Basic read/write access. In my experience the most profound
Implication of this is that you need to include the bus grant
"daisy chain" jumpers on non-self-configuring backplanes.
HTH -- Larry
> -----Original Message-----
> From: W T Meyer [mailto:[email protected]]
> Sent: Tuesday, November 09, 2004 7:03 PM
> To: [email protected]
> Subject: Multiple IOC's in a crate?
> Is it possible to run two or more IOCs in a single VME crate?
> At present
> we're running MVV-177 IOCs running VxWorks, but are
> considering upgrading.
> Tom Meyer
Multiple IOC's in a crate? W T Meyer
Prev: Multiple IOC's in a crate? W T Meyer
Next: Re: Multiple IOC's in a crate? Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
