1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Modbus and Wago
To: [email protected]
Date: 10 Nov 2004 11:28:52 -0500
Hello all,
  I am looking to make use of the Modbus/modTCP driver to control a
  Wago 750 unit.
I was able to find the original TRIUMF code but was not able to locate
  the Desy extensions for the wago controller.
Is there a public FTP for the source from desy?
I was also curious if anyone has looked in to using either version of
the modbus system under R3.16.x systems, or if there exist any plans
to make the modbus/modtcp system a supported module under R3.16
Bill Nolan.
[email protected]
"You do not examine legislation in the light of the benefits it will
convey if properly administered, but in the light of the wrongs it
would do and the harms it would cause if improperly administered."
       -Lyndon Johnson
Prev: RE: linux ioc console Allison, Stephanie
Next: Re: Options for local booting of vxWorks and applications Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Open Position at the Swiss Light Source Luedeke Andreas
Next: NFS performance problems on vxWorks Dirk Zimoch
