1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Options for local booting of vxWorks and applications
To: Andy Foster <[email protected]>
Cc: Epics Questions <[email protected]>
Date: Wed, 10 Nov 2004 17:58:51 +0100
Hello Andy,
we at SLS are planning a solution with Compact Flash cards and
PMC CF (PMC234) adapters from RAMIX (or GE Fanuc Embedded Systems, http://www.geindustrial.com/cwc/gefanuc/embedded/)
that plug on an IOC PMC slot. I could bring the system (mv5110) to boot from the CF, but unfortunately have too little time to get
further than that. However, now the work is continued by another
person and hopefully we will be running soon (although that person
is also quite loaded with work.)
To boot from CF one needs a few modifications to the vxWorks kernel;
the bootrom also needs to be rebuilt. TrueFFS is not required (although
I first thought so) because the CF card has a normal IDE interface.
When one gets that to work, it looks actually rather nice; the CF
looks like a normal disk where one can simply copy files. Booting
is really quick.
We plan also to use industrial grade CF cards (for example from
SanDisk) which are guaranteed for 2 million write/erase cycles
and have a 7-year guarantee. They are a bit more expensive than normal
commercial versions, but the increased reliability should more
than offset the costs.
Cheers,
Timo
Andy Foster wrote:
Hello All,
I was just investigating what options there are for booting
vxWorks applications locally, rather than across the network and
was wondering if any sites are already doing this?
It seemed that one option is to use a SCSI device with a DOS file
system attached.
Is anyone using Compact Flash or any other type of local memory?
I am really interested in solutions for the MVME-2700 and
the MVME-5500 (in the future).
What we are trying to achieve is faster local boots, reducing the
network traffic at system startup.
Many thanks for any comments and/or examples.
Cheers,
Andy
Observatory Sciences Limited    Email: [email protected]
William James House             Tel: 44 - (0)1223 - 508259
Cowley Road                     Fax: 44 - (0)1223 - 508258
Cambridge, CB4 0WX, UK          http://www.observatorysciences.co.uk
Timo Korhonen  PSI (Paul Scherrer Institut)
               CH-5232 Villigen PSI
               tel + 41- 56 3103262  fax + 41 - 56 310 3383
e-mail:	       [email protected]
Options for local booting of vxWorks and applications Andy Foster
Prev: Re: Options for local booting of vxWorks and applications Andrew Johnson
Next: Re: linux ioc console Maren Purves
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Options for local booting of vxWorks and applications Andy Foster
Next: RE: Options for local booting of vxWorks and applications Baker, KA (Keith)
