I reported a problem with the Tornado 2.2.1 supplied compiler via the Mantis Bug Reporting mechanism; Bug ID #82. We're turning down the optimization level of the 68K C compiler in Base R3.14.7 to -O0 as a result of this bug. The C++ compiler is not affected. I guess this will also fix the calc record problem. For those who don't know, the Tornado 2.x C compiler is actually pretty ancient, being based on gcc 2.7.2 (1996). Their C++ compiler has a somewhat more recent origin, although it's still old (EGCS, 1997). WRS are rightly assuming that their customers need object code compatibility for existing object-only libraries, which any significant gcc upgrade would break. The best way to find your compiler version is to run the relevent compiler with a '-v' switch. - Andrew -- Dear God, I didn't think orange went with purple until I saw the sunset you made last night. That was really cool. - Caro
ANJ, 10 Aug 2010 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
