1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
Subject: Re: Building EPICS base
To: Krapec Iztok <[email protected]>
Cc: [email protected]
Date: Tue, 23 Nov 2004 17:15:06 +0100 (MET)
Please look at:
http://www.aps.anl.gov/epics/tech-talk/2004/msg00884.php
Jeff Hill posted a workaround solution.
Mauro.
On Tue, 23 Nov 2004, Krapec Iztok wrote:
> Hello
> I am trying to build EPICS base 3.14.6 and I am getting following error:
> make[3]: Entering directory
> `/home/ikrapec/epics-instal63/base-3.14.6/src/ca/O.linux-x86'
> /usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
> -D_XOPEN_SOURCE=500  -DOSITHREAD_USE_DEFAULT_STACK      -D_X86_  -DUNIX
> -D_BSD_SOURCE -Dlinux  -D_REENTRANT -ansi  -O3  -Wall           -I. -I..
> -I../../../include/os/Linux -I../../../include         ../casw.cpp
> In file included from ../casw.cpp:31:
> ../udpiiu.h:73: error: `virtual void udpRecvThread::run()' is private
> ../udpiiu.h:183: error: within this context
> make[3]: *** [casw.o] Error 1
> make[3]: Leaving directory
> make[2]: *** [install.linux-x86] Error 2
> make[2]: Leaving directory `/home/ikrapec/epics-instal63/base-3.14.6/src/ca'
> make[1]: *** [ca.install] Error 2
> make[1]: Leaving directory `/home/ikrapec/epics-instal63/base-3.14.6/src'
> make: *** [src.install] Error 2
> I am using gcc version 3.4.2 and GNU Make 3.80.
> Does somebody know what is the problem?
> LP
> Iztok
Building EPICS base Krapec Iztok
Prev: Building EPICS base Krapec Iztok
Next: RE: Building EPICS base Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <20042005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025
ANJ, 10 Aug 2010 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
