1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Labview Shared Memory Interface
To: <[email protected]>, <[email protected]>
Date: Fri, 3 Dec 2004 08:31:59 -0500
Mark,
You are probably accessing VI's that someone saved from LabVIEW 7. Those VI's will probably work with 6.x, but someone that has LabVIEW 7 will need to open the VI's and then do a Save_With_Options to save a version that is compatible with LabVIEW 6.
Now, to find a volunteer...
-ps
----- Original Message ----- From: <[email protected]>
Sent: Friday, December 03, 2004 12:51 AM
Subject: Labview Shared Memory Interface
Hi all,
Im looking at the shared memory interface between labview and EPICS. It
seems that I require Labview 7.1 to get the VI files to run. Can anybody
verify if this is correct ?
Many thanks,
Mark Clift
Control Systems Engineer
Australian Synchrotron Project
Level 17 Nauru House, 80 Collins Street Melbourne
www.synchrotron.vic.gov.au
Any personal or sensitive information contained in this email and
attachments must be handled in accordance with the Victorian Information
Privacy Act 2000, the Health Records Act 2001 or the Privacy Act 1988
(Commonwealth), as applicable.
This email, including all attachments, is confidential. If you are not the
intended recipient, you must not disclose, distribute, copy or use the
information contained in this email or attachments. Any confidentiality or
privilege is not waived or lost because this email has been sent to you in
error. If you have received it in error, please let us know by reply
email, delete it from your system and destroy any copies.
Labview Shared Memory Interface Mark . Clift
Prev: RE: Labview Shared Memory Interface Liyu, Andrei
Next: channel access errors Geoff Savage
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Labview Shared Memory Interface Mark . Clift
Next: RE: Labview Shared Memory Interface Liyu, Andrei
