1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: channel access errors
To: tech-talk <[email protected]>
Date: Mon, 06 Dec 2004 15:01:30 -0600
We noticed issues when we switched over too. Almost all of the problems were due to the way we wrote code for 3.13.x which was more forgiving to incorectly written code. Our main problem was seen in programs that ran in an internal loop where there might be 60 seconds or so between iterations. We found out that we could not simply have the code sleep because the new version of Epics thought we may have lost connection.
Our changes included:
Replacing all ca_pend_io and ca_pend_event commands that had short polling times with ca_poll.
Replacing sleep commands with ca_pend_event commands because Epics/Base 3.14.x has an inactivity timer that was causing disconnects from PVs when the log interval time was too large. Note that you have to be carefull because if you pass zero to ca_pend_event it takes that to mean infinite. In this case we simply do a ca_poll.
Ensured that all codes included the ca_task_exit at the end because if a ca_put was done directly prior to exiting there was a good chance that the buffer would not be flushed upon exit if ca_task_exit was not in the code.
--Bob
Geoff Savage wrote:
We have just finished upgrading about 75% of the control system nodes to EPICS 3.14.6/vxworks 5.5. The remaining nodes are running EPICS 3.13.4 with some patches/vxworks 5.3.1. We have noticed more channel access errors with the later version of epics in the system than with an all EPICS 3.13.4 system. Is this to be expected at this time? Will the EPICS 3.14.7 release remove the errors? I understand that I don't have any details but the situatuions encountered are not reporduceable and everyone can get their work done. Over the past week while we have installed the new software we have been fielding questions about error messages appearing that have not been seen before.
Geoff
channel access errors Geoff Savage
Prev: channel access errors Geoff Savage
Next: Initial value readback from hardware into output records Steven . Banks
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: channel access errors Jeff Hill
