1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Initial value readback from hardware into output records
To: "Russell Redman" <[email protected]>, <[email protected]>, <[email protected]>
Date: Tue, 7 Dec 2004 12:34:45 -0600
Title: Message
Russell,
The features I was discussing only apply to generic device support for drivers that use the new asynDriver interfaces.  Since your drivers are not based on asyn, and you are not using the asyn generic device support, then this will not be a problem for you.  Nothing in EPICS base has changed in this regard.
If you begin to use asyn-based drivers, and you don't want the records to set the value during init_record you can:
- Use non-generic device support
- Write an asyn SIMULATION driver, that looks just like the real driver, but does not talk to hardware
-----Original Message-----
Sent: Tuesday, December 07, 2004 10:44 AM
To: Mark Rivers; [email protected]; [email protected]
Subject: Re: Initial value readback from hardware into output records
I am curious about a closely related issue that I fear will arise when  we try to upgrade our version of EPICS from 3.13.8 to use the newer software.  My code runs in both hardware and simulation modes to allow the software to be tested without having the hardware attached.  When the IOC boots, it does not know which mode it is supposed to be in.  The operator sets HARDWARE/SIMULATION mode flag, then runs an INITIALISE action to open communications with hardware or with the simulator, as appropriate.  Very bad things happen if the EPICS drivers attempt to read back values from nonexistent hardware, and I have put a considerable effort into the startup code to ensure that I/O records do not process on startup.
So here is my question: How can I PREVENT an output record from reading back a value during init_record from hardware that may or may not exist?
Cheers,
Dr. Russell O. Redman
Tel: (250) 363-6917 | Fax: (250) 363-0045
<mailto:[email protected]>
National Research Council Canada | Conseil national de recherches Canada
5071 West Saanich Road           | 5071 West Saanich Road
Victoria, B. C. V9E 2E7          | Victoria, C.-B. V9E 2E7
Government of Canada             | Gouvernement du Canada
RE: Initial value readback from hardware into output records Ralph Lange
Prev: Re: Initial value readback from hardware into output records Russell Redman
Next: Re: Initial value readback from hardware into output records Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Initial value readback from hardware into output records Benjamin Franksen
Next: RE: Initial value readback from hardware into output records Ralph Lange
