1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: antelope on Solaris 9
To: <[email protected]>
Date: Thu, 16 Dec 2004 11:56:49 -0500
I had some difficulty compiling R3.14.7 on Solaris 9 with SunStudio 9. Initially, I needed to install the readline package which isn't in the base OS. But then, src/toolsComm/antelope wouldn't build. To get it to build I had to change a line in base-3.14.7/configure/os/CONFIG.Common.solaris-sparc. I appended -lcurses to the line COMPILER_LDFLAGS += -mt .
Is this a build issue that others have had on Solaris 9, or did I miss the more elegant solution?
Paul Sichta
Princeton Plasma Physics Laboratory
609-243-3477 FAX 3030
Re: antelope on Solaris 9 Andrew Johnson
Prev: ICALEPCS'05 at CERN Matthias Clausen
Next: Re: antelope on Solaris 9 Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  <2004>  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
