1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: if-then-else in iocsh
To: [email protected]
Cc: Emmanuel Mayssat <[email protected]>
Date: Fri, 28 Jan 2005 09:39:46 -1000
Andrew Johnson wrote:
Emmanuel Mayssat wrote:
I would like to check for the settings of an environment variable in
iocsh. If the envrionment variable is not set, then I want to set it to
a default value.
Is there any way to do that ?
Yes, but how depends what variables you're trying to set, and whether this is for a particular IOC or all IOCs using a particular version of EPICS Base. The ioc shell is not intended to be a programming language, and it doesn't (and never will) provide conditional commands, so you can't just put something in the startup script that will work for any environment variable.
I had interpreted this yet different, and my first reaction was
"you use a subroutine record" ...
What are you trying to do?
Aloha,
Maren
Re: if-then-else in iocsh Emmanuel Mayssat
Re: if-then-else in iocsh Andrew Johnson
Prev: Re: if-then-else in iocsh Andrew Johnson
Next: Re: if-then-else in iocsh Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
